Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury. Place the Cinema Display so that it is lying on its face and the feet are pointed away from you. Locate the three screws that connect the back foot to the hinge. Remove the three screws (9.52 x 4.43mm) using the Hex Key.
  • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
  • Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
  • Locate the three screws that connect the back foot to the hinge. Remove the three screws (9.52 x 4.43mm) using the Hex Key.
  • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
Avant de commencer, assurez-vous que l’écran est UNPLUGGED. Dans le cas contraire, vous risquez de vous électrocuter et de vous blesser gravement.
Retournez le Cinéma pour qu’il soit face visible et que les pieds ne soient pas dirigés vers vous.
À l’aide du tournevis PH 2, dévissez les vis à trois pieds (9,52 x 4,43 mm).
Retirez le pied arrière du support de charnière en le saisissant et en le tirant vers le haut.
[* icon_caution] Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
-[* black] Flip the Cinema Display so it is on its face and the feet are pointed away from you.
-[* red] Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
+[* black] Place the Cinema Display so that it is lying on its face and the feet are pointed away from you.
+[* red] Locate the three screws that connect the back foot to the hinge. Remove the three screws (9.52 x 4.43mm) using the Hex Key.
[* black] Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
