Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
Locate the control board on the right side. Carefully remove the two orange tape plugs on either side of the control board using the spudger. Locate the control board on the right side. Carefully remove the two orange tape plugs on either side of the control board using the spudger. Locate the control board on the right side. Carefully remove the two orange tape plugs on either side of the control board using the spudger.
  • Locate the control board on the right side. Carefully remove the two orange tape plugs on either side of the control board using the spudger.
Localisez et retirez délicatement les deux bouchons de ruban adhésif de chaque côté de la carte de contrôle à l'aide du spudger.
-[* red] Locate and carefully remove the two tape plugs on either side of the control board using the spudger.
+[* red] Locate the control board on the right side. Carefully remove the two orange tape plugs on either side of the control board using the spudger.
