Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
Locate the four screws (4.79x2.33mm) on the four corners of the metal box. Remove the screws using the PH 2 screwdriver. Lift away the metal cover with your hand to reveal the circuit board. Unscrew the two terminal screws (4.79x2.34mm) located at the bottom of the circuit board, by using the PH 2 screwdriver.
  • Locate the four screws (4.79x2.33mm) on the four corners of the metal box. Remove the screws using the PH 2 screwdriver.
  • Lift away the metal cover with your hand to reveal the circuit board.
  • Unscrew the two terminal screws (4.79x2.34mm) located at the bottom of the circuit board, by using the PH 2 screwdriver.
Dévissez les quatre vis (4.79x2.33mm) du boîtier en métal à l’aide du tournevis PH 2.
Soulevez le couvercle en métal pour révéler un circuit imprimé avec votre main.
Dévissez les deux vis des bornes (4,79 x 2,34 mm) à l’aide du tournevis PH 2.
-[* red] Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver.
-[* black] Lift away the metal cover to reveal a circuit board with you hand.
-[* green] Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
+[* red] Locate the four screws (4.79x2.33mm) on the four corners of the metal box. Remove the screws using the PH 2 screwdriver.
+[* black] Lift away the metal cover with your hand to reveal the circuit board.
+[* green] Unscrew the two terminal screws (4.79x2.34mm) located at the bottom of the circuit board, by using the PH 2 screwdriver.
