Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 4
Étape 4
From where you removed the screws in the previous step, remove the cover of the terminal. Gently lift and remove the circuit board from the right side of the unit.
  • From where you removed the screws in the previous step, remove the cover of the terminal.
  • Gently lift and remove the circuit board from the right side of the unit.
  • Replace the circuit board and follow these steps in reverse to put it back together again.
Retirez le cache-bornes.
Retirez le circuit imprimé du côté droit de l'appareil en le soulevant doucement.
-[* black] Remove the terminal cover.
-[* black] Remove the circuit board from the right side of the unit by gently lifting it out.
+[* black] From where you removed the screws in the previous step, remove the cover of the terminal.
+[* black] Gently lift and remove the circuit board from the right side of the unit.
+[* black] Replace the circuit board and follow these steps in reverse to put it back together again.
