Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 6
Étape 6
Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case. Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case. Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
  • Insert an opening pick under the Lightning connector flex cable and slowly slice through the adhesive holding the cable to the rear case.
Insérez un médiator entre le support de mise à terre supérieur droit de la nappe et la coque arrière et commencez à les séparer.
[* black] Insert an opening pick betweenunder the Lightning connector flex cable's upper right grounding bracketcable and slowly slice through the rear caseadhesive holding the cable to begin separating the tworear case.
