Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Remplacement du connecteur de charge Lightning et de la prise Jack de l'iPhone 6s Plus
Informations sur le tutoriel
= Terminé = Incomplet
    Follow the steps in this guide to replace the lower flex cable in an iPhone 6s Plus. This cable assembly is home to the headphone jack and Lightning connector. If your phone is having trouble charging or connecting via USB, or you have a loose headphone jack, replacing this component can resolve your issue. [ … ] Note that it's possible to replace this component while leaving the logic board installed, by skipping steps 22-37, 40-49, and 53. Then in step 56, instead of removing the speaker, you must either carefully move it out of the way, or detach it from the black antenna cables so you can remove it. Afterward, when removing the Lightning connector assembly, you must be extra careful not to pry against the logic board or battery. This approach leaves you less room to work, but eliminates a lot of steps. [ ] YouYou can also use this guide to replace the '''[https://www.ifixit.com/Guide/iPhone+6s+Plus+Lightning+Connector+and+Headphone+Jack+Replacement/54171#s119184| lightning connector bracket]'''. bracket.
      ToCompare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing. [ ] '''To reassemble your device, follow these instructions in reverse order. order.''' [ ] Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]]. [ ] Repair didn’t go as planned? Check out our [https://www.ifixit.com/Answers/Device/iPhone%206s%20Plus|iPhone 6s Plus Answers community] for troubleshooting help.
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
      Étape 1
      À l'aide de l'extrémité pointue d'une spatule, déconnectez la nappe du Taptic Engine de la nappe inférieure.
      Étape 2
      Retirez les vis suivantes, maintenant le Taptic Engine en place :
      Étape 3
      Décollez le morceau de bande adhésive, qui recouvre la vis fixant la nappe du connecteur de charge au rebord du téléphone.
      Étape 4
      Dévissez les cinq vis cruciformes suivantes :
      Étape 5
      Préparez un iOpener et posez-le sur le bas de votre téléphone pour faire ramollir l'adhésif maintenant la nappe du connecteur de charge Lightning en place.
      Étape 6
      Insérez un médiator entre le support de mise à terre supérieur droit de la nappe et la coque arrière et commencez à les séparer.
      Étape 7
      Continuez à le faire glisser sous la nappe.
      Étape 8
      Avec un médiator, faites levier sur le microphone gauche pour le séparer du bord de la coque arrière.
      Étape 9
      Répétez l'étape précédente pour le microphone inférieur droit.
      Étape 10
      Avec l'extrémité pointue d'une spatule (spudger), poussez la prise Jack de 3,5 mm hors de son emplacement dans la coque arrière.
