Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Turn the computer over and open the display. You should see that the keyboard is loose. Before attempting to remove the keyboard, note that a ribbon cable connects  the keyboard to the logic board. Improper removal may damage your keyboard. Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
  • Turn the computer over and open the display. You should see that the keyboard is loose.
  • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
  • Carefully lift the front of the keyboard up slightly, and then slide the keyboard towards yourself.
  • Then carefully lift the top half of the keyboard, and rotate it towards yourself.
Insérez ici votre traduction
