Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Rotate it so the display is on your right and the keyboard is on your left. Lift the switch cover firmly but slowly so you do not snap it. Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
  • Rotate it so the display is on your right and the keyboard is on your left.
  • Lift the switch cover firmly but slowly so you do not snap it.
  • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
  • The switch cover should easily separate from the laptop as you run the spudger through.
Insérez ici votre traduction
