Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Using a plastic opening tool, detach the plastic casing from keyboard. This may require some force. Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard. Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
  • Using a plastic opening tool, detach the plastic casing from keyboard. This may require some force.
  • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
  • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
Insérez ici votre traduction
