Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw. If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw.
Install 3rd Washer Under Each Screw
  • If the PS4 still does not work after adding two washers you will then remove the heat sink clamp and add a third washer under each heat sink clamp screw.
Si la PS4 ne fonctionne toujours pas après avoir ajouté 2 rondelles, retirez le clamp du refroidisseur et ajouter une troisième rondelle sous chaque vis du clamp.
