Aller au contenu principal
Remplacement du haut-parleur interne de l'iPhone 6s
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Traduction de l’étape 4
Anglais
Français
Étape 4
iPhone 6s Earpiece Speaker Replacement: étape 0, image 1 de 2 iPhone 6s Earpiece Speaker Replacement: étape 0, image 2 de 2
  • Pull back the front-facing camera to access the earpiece speaker.
  • Remove the earpiece speaker.
  • Be careful not to touch the golden contacts as you remove and replace the speaker. Oil from your skin can interfere with the contacts and interrupt the connection. If you accidentally touch them with your skin, wipe them off with a little isopropyl alcohol (rubbing alcohol) before reinstalling them.
Eloignez la caméra frontale vers l'arrière pour accéder au haut-parleur interne.
Retirez le haut-parleur interne.
Attention à ne pas toucher les contacts dorés lorsque vous enlevez et remplacez le haut-parleur. Le sébum de la peau risque de causer des faux-contacts. Si vous touchez accidentellement les contacts, nettoyez-les avec un peu d'alcool isopropylique avant de les réinstaller.
[* black] Pull back the front-facing camera to access the earpiece speaker.
[* black] Remove the earpiece speaker.
-[* icon_note] Be careful not to touch the golden contacts as you remove and replace the speaker. Oil from your skin can interfere with the contacts interrupt the connection. If you accidentally touch them with your skin, wipe them off with a little isopropyl alcohol (rubbing alcohol) before reinstalling them.
+[* icon_note] Be careful not to touch the golden contacts as you remove and replace the speaker. Oil from your skin can interfere with the contacts and interrupt the connection. If you accidentally touch them with your skin, wipe them off with a little isopropyl alcohol (rubbing alcohol) before reinstalling them.
