Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 6
Étape 6
If you're just trying to remove the rear panel, you can skip Steps 30 and 31. If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If you're just trying to remove the rear panel, you can skip Steps 30 and 31.
  • If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack.
  • Remove the single Phillips screw nearest to the hold switch.
  • Lift the plastic portion of the Hold switch away from the orange ribbon cable.
  • Ensure that the black notch lines up with the gray slider during reassembly of the switch (see picture 2).
Si vous essayez simplement de retirer le panneau arrière, vous pouvez ignorer les étapes 30 et 31.
Si votre prise casque de remplacement comprend le bouton Arrêt en plastique blanc, il suffit de réinstaller la prise casque de remplacement. Lorsque vous remplacez le bouton Arrêt, notez la goupille de localisation située près du trou, la position de la vis en argent. Concentrez -vous sur ceci et le reste s'imbriquera tout seul.
Une fois que le tout est revissé, n'oubliez pas de décoller le ruban adhésif de la plaquette de contact le long de la prise casque.
Si votre pièce de rechange ne comprend pas le bouton Arrêt en plastique, suivez les étapes suivantes pour transférer le bouton Arrêt en plastique sur votre nouvelle prise casque.
Retirez la vis cruciforme la plus proche du bouton Arrêt.
Enlevez de la nappe orange la partie en plastique du bouton Arrêt.
Assurez-vous que l'entaille noire s'aligne avec le curseur gris lors du remontage du bouton (voir photo 2).
