Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Once the metal plate is off, inspect the inside of the device to be sure the battery is plugged in and there's nothing blocking it. Battery malfunction is often caused by internal components that are dirty. Be sure the battery clip is plugged in properly and then reassemble device. Hold the power button and start the device up. Battery malfunction is often caused by internal components that are dirty. Be sure the battery clip is plugged in properly and then reassemble device. Hold the power button and start the device up.
  • Once the metal plate is off, inspect the inside of the device to be sure the battery is plugged in and there's nothing blocking it.
  • Battery malfunction is often caused by internal components that are dirty. Be sure the battery clip is plugged in properly and then reassemble device. Hold the power button and start the device up.
Insérez ici votre traduction
