Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
To replace the battery, simply insert a new one into the same slot and then plug in the end to the correct spot. After the device is assembled, power the device on. The issue should be repaired. If the device battery is still defective, a greater issue is the cause.
  • To replace the battery, simply insert a new one into the same slot and then plug in the end to the correct spot.
  • After the device is assembled, power the device on. The issue should be repaired.
  • If the device battery is still defective, a greater issue is the cause.
Insérez ici votre traduction
