Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 4
Étape 4
If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case. Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or  hair dryer.
  • If you successfully removed both adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
  • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
  • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
  • Do not insert your card in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath.
  • Do not pry against the logic board or you may damage the phone.
  • Keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals or catch fire. Do not use any sharp tools to pry at the battery.
  • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
  • Thread the floss or string behind the upper battery corners, bring the ends together, wrap them around a folded cloth, and pull evenly.
Si vous avez retiré avec succès les trois bandes adhésives, passez à l'étape suivante. Sinon, vous aurez besoin de dégager la batterie du boîtier arrière.
Préparer un iOpener et l'appliquer à l'arrière du boîtier arrière, directement sur la batterie. Alternativement, vous pouvez appliquer de la chaleur à l'aide d'un pistolet thermique ou d'un sèche-cheveux.
Après environ une minute, retournez le téléphone et utilisez une carte en plastique pour briser tout adhésif restant derrière la batterie.
N'insérez pas la carte depuis la droite,le câble des boutons volume pourrait être endommagé.
N'appliquez pas de force à la carte mère car vous pourriez l'endommager.
Gardez la carte en plastique le plus plat possible afin d'éviter de plier la batterie, ce qui pourrait l'abîmer et émettre des substances dangereuses ou prendre feu. N'utilisez pas d'outil tranchant pour retirer la batterie.
Alternativement, un morceau de fil dentaire peut être utilisé afin de séparer la batterie de la coque arrière. Un autre alternatif plus solide qu'un fil dentaire serait une corde de guitare enroulée, comme la 0,0009E d'un set de 12 cordes.
Filez le fil dentaire ou la corde, placez-le/la dans les coins supérieurs de la batterie, enroulez les extrémités dans un morceau de tissu, puis tirez vers vous.
