Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
The top plate of the device is attached by a dot of glue. Use the metal  spudger to pry the plate off. After the top plate is removed, remove the four 4mm screws that attach the inner plate. When the plate is removed, the motherboard will be ready to be removed.
  • The top plate of the device is attached by a dot of glue. Use the metal spudger to pry the plate off.
  • After the top plate is removed, remove the four 4mm screws that attach the inner plate.
  • When the plate is removed, the motherboard will be ready to be removed.
Insérez ici votre traduction
