Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive. Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws. Be sure to keep the 4mm screws together and organized on the device magnet plate.
  • Remove the bottom panel with the metal spudger. This panel may be fused to the outer shell with a dot of adhesive.
  • Four screws fasten a metal plate to the device. Using the device magnetic mat and 54 bit (Phillips J000) driver, remove the screws.
  • Be sure to keep the 4mm screws together and organized on the device magnet plate.
Insérez ici votre traduction
