Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Use a plastic opening tool to flip up the lock on the display cable ZIF connector. Pull the display cable from its socket on the motherboard. When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
  • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
  • Pull the display cable from its socket on the motherboard.
  • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
Utilisez un outil d'ouverture en plastique pour soulever le verrou du connecteur de l'écran (voir photo)
Tirez le câble de l'écran pour le déconnecter de la carte mère.
[* black] Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
[* black] Pull the display cable from its socket on the motherboard.
[* icon_reminder] When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as [product|IF317-072|Tesa 61395]. Turn your phone on and test your repair before sealing the display in place.
