Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
Remove the Inner Cover Screws
  • Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
  • The black screws are 2.8 mm in length.
  • The silver screw is 5.5 mm in length.
  • The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
Dévissez les 13 vis noires et 1 vis grise du dos du téléphone avec un tourne-vis JIS taille 00.
Les vis noires font 2,8 mm de longueur.
La vis grise fait 5,5 mm de longueur.
La vis noire proche de la caméra est cachée par un autocollant. Cette vis peut aussi être dévissée facilement comme s'il n'y avait pas d'autocollant. La pointe du tournevis devrait percer facilement l'autocollant.
[title] Remove the Inner Cover Screws
[* black] Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
[* red] The black screws are 2.8 mm in length.
[* orange] The silver screw is 5.5 mm in length.
[* icon_note] The black screw next to the camera and the flash is covered by a sticker. This screw can be easily removed as if there were no sticker on top of it. The point of the screwdriver should be able to pierce through the sticker easily.
