Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 8
Étape 8
If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones Pull this tab gently in order to remove the cable
  • If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
  • If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
  • Pull this tab gently in order to remove the cable
  • Again, wiggling also helps
Insérez ici votre traduction
