Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 6
Étape 6
Disconnect the right side connector (output) on the power supply and Gently pull the power supply out while feeding the connector under the metal bracket The wires from the power supply to the connector are JUST long enough to allow disconnecting the connector.  REMEMBER this when you install new Power supply to avoid damaging it
  • Disconnect the right side connector (output) on the power supply and Gently pull the power supply out while feeding the connector under the metal bracket
  • The wires from the power supply to the connector are JUST long enough to allow disconnecting the connector. REMEMBER this when you install new Power supply to avoid damaging it
Insérez ici votre traduction
