Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver. Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened. The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
  • After removing the rubber stoppers on top, there should be six exposed screws. Remove these using the T6 screwdriver.
  • Next, use the spudger to loosen the case underneath the shiny metal edge. Go all the way around the phone until completely loosened.
  • The case is superglued on and will not permanently damage the phone when removed, but you should still use caution.
  • After loosening the case, remove it.
  • There is a wire that connects both the top and bottom of the case. If you are not careful when removing the case, you might snap the wire.
Insérez ici votre traduction
