Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Do not push the AirPort/Bluetooth card away from the logic board more than 1-2 mm. Doing so may cause severe damage. With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board. Try not to touch the antenna connector sockets with your fingers, as the oils can corrode the metal and prevent good contact.
  • Do not push the AirPort/Bluetooth card away from the logic board more than 1-2 mm. Doing so may cause severe damage.
  • With a firm grip on the edges of the AirPort/Bluetooth card, pull it straight out of its socket on the underside of the logic board.
  • Try not to touch the antenna connector sockets with your fingers, as the oils can corrode the metal and prevent good contact.
Insérez ici votre traduction
