Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 27 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
  • Lift the display up from the frame and remove it from the iMac.
  • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
  • Be very careful handling the display—it's big, heavy, and made of glass.
  • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Soulevez l'écran hors du cadre et retirez-le de l'iMac.
Il peut s'avérer nécessaire de l'élever lentement d'un côté pour le décoller de l'adhésif restant.
Faites très attention à l'écran : il est grand, lourd et en verre.
Une fois l'adhésif coupé, il ne peut pas être utilisé pour recoller l'écran. Suivez ce tutoriel pour remplacer les bandes adhésives qui fixent l'écran au boîtier arrière.
[* black] Lift the display up from the frame and remove it from the iMac.
[* black] It may be necessary to slowly lift from one side to peel against the remaining adhesive.
[* icon_caution] Be very careful handling the display—it's big, heavy, and made of glass.
-[* icon_reminder] After the adhesive is cut, it cannot be used to re-seal the display in place. Follow [guide|64210|this guide|new_window=true] to replace the adhesive strips that secure the display to the rear enclosure.
+[* icon_reminder] After the adhesive is cut, it cannot be used to re-seal the display in place. Follow [guide|137411|this guide] to replace the adhesive strips that secure the display to the rear enclosure.
