Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 25 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket. Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
  • Use the tip of a spudger to push each side of the power supply control cable connector and gently walk it out of its socket.
À l'aide de la pointe d'un spudger, poussez doucement chaque côté du connecteur du câble de commande de l'alimentation vers le haut pour débrancher le connecteur de sa prise.
-[* black] In the same manner as previously described, gently push upward with the tip of a spudger on each side of the power supply control cable connector.
+[* black] Use the tip of a spudger to push each side of the power supply control cable connector and gently ''walk'' it out of its socket.
