Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 11
Étape 11
This step deals with the indicated area. Using fingers or tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device. While holding the latch to the right, lift the unit up from the plastic.
  • This step deals with the indicated area.
  • Using fingers or tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device.
  • While holding the latch to the right, lift the unit up from the plastic.
  • CAUTION: When the latch is disengaged, the tape cover may push out and force the rest of the apparatus to pop up. This is normal, but be careful that the tape cover does not pop out too quickly.
  • NOTE: When placing this unit back on the device, you don't need to follow this step, you can simply push the unit into position and the latch will automatically snap into position.
Insérez ici votre traduction
