Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Now gently separate the metal bezel from the main body of the LCD panel Lay the LCD panel down on with viewing side UP and remove the metal bezel Make sure you are careful when removing the bezel from the TOP edge as you will be exposing the 8 flex cables mentioned in step 1.
  • Now gently separate the metal bezel from the main body of the LCD panel
  • Lay the LCD panel down on with viewing side UP and remove the metal bezel
  • Make sure you are careful when removing the bezel from the TOP edge as you will be exposing the 8 flex cables mentioned in step 1.
  • Note the 3 flex tabs on the left edge
  • Do not damage any of the tabs or flex cables as these are the Row and Column Drivers. Damage to these will will cause faults like vertical/horizontal lines or white screen etc.
  • WARNING - Once the bezel is removed the LCD is LOOSE in the black plastic frame - only held in by the small gasket underneath.
Insérez ici votre traduction
