Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the white tape from either end of the rear of the CCFL assembly. Carefully remove about 15-20mm of heat shrink from the CCFL cable to allow the end cap to be removed, making sure you DO NOT cut or nick the wire insulation. The wires have a HIGH VOLTAGE applied during operation and the insulation may break down if damaged causing a short
  • Remove the white tape from either end of the rear of the CCFL assembly.
  • Carefully remove about 15-20mm of heat shrink from the CCFL cable to allow the end cap to be removed, making sure you DO NOT cut or nick the wire insulation.
  • The wires have a HIGH VOLTAGE applied during operation and the insulation may break down if damaged causing a short
  • While holding the assembly, slowly and gently pull the THICK wires up and out of the slots in the white rubber cap.
  • Pull the wires one at a time ensuring you don't flex the CCFL and break it.
  • This will reveal the pins and solder joints.
Insérez ici votre traduction
