Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 8
Étape 8
Using the tip of a spudger to start, peel the adhesive backings off of the strips on the front panel plastic. The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself. The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself.
  • Using the tip of a spudger to start, peel the adhesive backings off of the strips on the front panel plastic.
  • The adhesive backing is fairly thin, be sure you are only peeling up the backing and not the adhesive itself.
A l'aide de la pointe d'une spatule (spudger), retirez le film adhésif des bandes collées sur le support du panneau frontal.
Le film adhésif est extrêmement fin. Veillez à retirer seulement le film et non la bande adhésive elle-même.
