Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Slide the phone apart, and remove a 5th screw (3.5 mm). Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction) The device will now be in two pieces
  • Slide the phone apart, and remove a 5th screw (3.5 mm).
  • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
  • The device will now be in two pieces
Faites glisser le téléphone et retirez une 5ème vis (3,5 mm).
Retirez la coque extérieure en soulevant les bords avec vos doigts ou un petit tournevis. (deuxième image, prise avant l'image pour l'instruction ci-dessus)
L'appareil sera maintenant en deux parties
-[* black] Slide the phone apart, and remove a 5th screw (3.5 mm).
+[* yellow] Slide the phone apart, and remove a 5th screw (3.5 mm).
[* black] Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
[* black] The device will now be in two pieces
