Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 99 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the following ten screws securing the lower case to the upper case:
Lower Case
  • Three 13.5 mm (14.1 mm) Phillips screws.
  • Seven 3 mm Phillips screws.
  • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
Retirez les dix vis suivantes, fixant le boîtier inférieur au boîtier supérieur :
Trois vis Phillips 13,5 mm (14,1 mm).
Sept vis Phillips 3 mm.
[title] Lower Case
[* black] Remove the following ten screws securing the lower case to the upper case:
[* orange] Three 13.5 mm (14.1 mm) Phillips screws.
[* red] Seven 3 mm Phillips screws.
[* icon_reminder] When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
