Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
Press both audio ports down slightly, then lift the audio port assembly out of the outer case. A pair of tweezers is helpful to put the ports back in place. First insert the lower tab into the bracket on the outer case, then fasten the screw to secure the jack to the outer case.
  • Press both audio ports down slightly, then lift the audio port assembly out of the outer case.
  • A pair of tweezers is helpful to put the ports back in place. First insert the lower tab into the bracket on the outer case, then fasten the screw to secure the jack to the outer case.
  • During reinstallation, it may be helpful to plug in a pair of headphones to each jack before tightening them down completely.
Insérez ici votre traduction
