Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 13 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
You should now have one orange ribbon cable still attaching the front case to the back.
  • You should now have one orange ribbon cable still attaching the front case to the back.
  • At this point you are able to remove and replace the blue rubber bumpers, or continue with separating the case.
  • Separating the case is not necessary to complete battery replacement but may facilitate ease of replacement. It does require removing an extra cable at some risk of damage during removal.
Vous devriez maintenant voir une nappe orange reliant toujours la coque avant à l'arrière.
À ce stade, vous pouvez enlever et remplacer les protections en caoutchouc bleu ou continuer en séparant le boîtier.
La séparation du boîtier n'est pas nécessaire pour terminer le remplacement de la batterie, mais peut faciliter la réparation. Il nécessite de retirer un câble supplémentaire qui risque d'être endommagé lors du retrait.
[* black] You should now have one orange ribbon cable still attaching the front case to the back.
[* black] At this point you are able to remove and replace the blue rubber bumpers, or continue with separating the case.
-[* icon_note] Separating the case is not necessary to complete battery replacement but may facilitate ease of replacement. It does require removing an extra cable at some risk of damage during removal
+[* icon_note] Separating the case is not necessary to complete battery replacement but may facilitate ease of replacement. It does require removing an extra cable at some risk of damage during removal.
