Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame. If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display. Insert an opening pick into the gap.
  • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
  • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
  • Insert an opening pick into the gap.
  • There are tabs on the upper right side and upper left side where it is easier to get a tool under the display.
  • Slide an opening pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
  • The tape is much thinner on the bottom edge than the other three sides. Do not push the tool in too far or you will damage the screen permanently.
  • Work carefully—the glass is thin and will crack easily if you try to force it.
  • Separate the top edge last. There are antennas on both sides, so be careful not to damage them. If needed, you can use a bit of isopropyl alcohol to help weaken the adhesive.
Utilisez une ventouse ou un iSlack pour soulever la vitre et ouvrir un léger espace entre la vitre et le châssis en métal.
Si l'écran est trop endommagé, il se peut que la ventouse n'adhère pas. Dans ce cas, il peut être utile de poser une couche de ruban adhésif. Il est aussi possible de coller avec de la colle forte votre ventouse à l'écran.
Insérez un médiator dans l'espace.
Il y a des onglets dans les coins supérieurs droit et gauche, là où il est plus facile d'insérer un outil sous l'écran.
Faites glisser le médiator sur tout le long des côtés et du bas de l'écran afin de couper l'adhésif. Refaites chauffer si nécessaire.
La colle est plus fine sur le bord inférieur que sur les autres côtés. N'enfoncez pas l'outil trop loin ou vous risquer d'endommager l'écran de façon irréversible.
Faites attention : la vitre est fine et se casse facilement si vous tentez de forcer.
Séparez le côté supérieur de l'écran en dernier. Il y a des antennes sur les deux côtés, il ne faut pas les endommager. Si besoin, vous pouvez utiliser de l'alcool isopropylique pour ramollir l'adhésif.
