Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
The display should now be free of the body of the Surface Pro. Lift it up and away from the rest of the device. Before installing a new display, check it carefully to see if any parts need to be transferred over from the back of the old display to the new display. In particular, you may need to transfer over the NTrig board in the corner by disconnecting the two attached ribbon cables and using heat and gentle prying to carefully separate the glue securing the board. To replace the adhesive securing the display, carefully remove any old adhesive from both the device and the back of the display. Clean and prep the surface with isopropyl alcohol and a lint-free cloth, swiping the cloth in one direction (not back and forth). Apply a strong double-sided tape, such as 2 mm Tesa 61395.
  • The display should now be free of the body of the Surface Pro. Lift it up and away from the rest of the device.
  • Before installing a new display, check it carefully to see if any parts need to be transferred over from the back of the old display to the new display. In particular, you may need to transfer over the NTrig board in the corner by disconnecting the two attached ribbon cables and using heat and gentle prying to carefully separate the glue securing the board.
  • To replace the adhesive securing the display, carefully remove any old adhesive from both the device and the back of the display. Clean and prep the surface with isopropyl alcohol and a lint-free cloth, swiping the cloth in one direction (not back and forth). Apply a strong double-sided tape, such as 2 mm Tesa 61395.
L'écran devrait maintenant se détacher de reste de la Surface Pro. Soulevez-le et ôtez-le.
Avant d'installer un nouvel écran, vérifiez attentivement si des pièces doivent être transférées de l'ancien écran vers le nouveau. En particulier, vous devrez peut-être transférer la carte NTrig dans le coin en déconnectant les deux nappes qui y sont reliées et en la chauffant pour ensuite décoller délicatement la carte de l'écran.
Pour remplace l'adhésif de l'écran, enlevez avec précaution les résidus d'adhésif du châssis de l’appareil et de l'arrière de l'écran. Nettoyez et préparez la surface avec de l'alcool isopropylique et un chiffon non pelucheux, en essuyant dans un seul sens. Appliquez un ruban adhésif double-face solide, tel que le Tesa 61395 de 2 mm.
