Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 12
Étape 12
Removing the battery before lifting out the logic board is not strictly required, but makes removing the logic board easier and safer. If you leave your battery in, be especially careful not to bend the logic board against the battery's case near its bar code. Remove the following Tri-point screws securing the battery to the upper case:
  • Removing the battery before lifting out the logic board is not strictly required, but makes removing the logic board easier and safer. If you leave your battery in, be especially careful not to bend the logic board against the battery's case near its bar code.
  • Remove the following Tri-point screws securing the battery to the upper case:
  • One 5.5 mm Tri-point screw
  • One 13.5 mm Tri-point screw
  • Lift the battery out of the upper case.
Il n'est pas absolument nécessaire d'enlever la batterie avant de retirer la carte mère mais cela rend cette étape plus facile et plus sûre. Si vous laissez la batterie à l'intérieur, soyez particulièrement attentif à ne pas heurter la carte mère au boîtier de la batterie à côté du code barres.
Dévissez les vis tri-wing suivantes, fixant la batterie au boîtier supérieur :
Une vis tri-wing de 5,5 mm
Une vis tri-wing de 13,5 mm
Ôtez la batterie du boîtier supérieur.
[* icon_note] Removing the battery before lifting out the logic board is not strictly required, but makes removing the logic board easier and safer. If you leave your battery in, be especially careful not to bend the logic board against the battery's case near its bar code.
[* black] Remove the following Tri-WingTri-point screws securing the battery to the upper case:
[* red] One 5.5 mm Tri-WingTri-point screw
[* orange] One 13.5 mm Tri-WingTri-point screw
[* black] Lift the battery out of the upper case.
