Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 5
Étape 5
If your replacement headphone jack includes the white plastic hold switch, simply reinstall the headphone jack. If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack. If you're just trying to remove the rear panel, you can skip Steps 15 and 16.
  • If your replacement headphone jack includes the white plastic hold switch, simply reinstall the headphone jack. If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack.
  • If you're just trying to remove the rear panel, you can skip Steps 15 and 16.
  • Remove the single Phillips screw nearest to the hold switch. Note: You may find adhesive holding the back of the screw in place.
  • Lift the plastic portion of the Hold switch away from the orange ribbon cable.
  • Ensure that the black notch lines up with the gray slider during reassembly of the switch (see picture 2).
Insérez ici votre traduction
