Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Using the plastic opening tool pry the  upper motherboard. Carefully pry it up until you can safely remove the upper motherboard completely. Be careful when pulling up the upper motherboard, the front camera is clipped underneath and pulling too hard may damage it. On the bottom left hand side of the phone, you will see a small screw. Use  the PH #000  to remove that screw.
  • Using the plastic opening tool pry the upper motherboard. Carefully pry it up until you can safely remove the upper motherboard completely.
  • Be careful when pulling up the upper motherboard, the front camera is clipped underneath and pulling too hard may damage it.
  • On the bottom left hand side of the phone, you will see a small screw. Use the PH #000 to remove that screw.
Insérez ici votre traduction
