Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
After removing the Phillips head screw,  you will need to remove a black wire. Use a spudger to unclip the cable first. It might be helpful to bend the cable out of the way when working on the phone. Pull back on the ribbon-cable as shown in the image. This is connected to both the charging port and the vibration module (which is similar to a small watch battery).
  • After removing the Phillips head screw, you will need to remove a black wire. Use a spudger to unclip the cable first.
  • It might be helpful to bend the cable out of the way when working on the phone.
  • Pull back on the ribbon-cable as shown in the image. This is connected to both the charging port and the vibration module (which is similar to a small watch battery).
  • Gently pry the vibration module out with a plastic opening tool. Be gentle, for it is adhered to the phone.
  • You will need to remove the vibration module before the charging port.
Insérez ici votre traduction
