Aller au contenu principal
Dell Inspiron 15 3541 Hard Drive Replacement
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 1
Étape 1
Dell Inspiron 15 3541 Hard Drive Replacement: étape 0, image 1 de 3 Dell Inspiron 15 3541 Hard Drive Replacement: étape 0, image 2 de 3 Dell Inspiron 15 3541 Hard Drive Replacement: étape 0, image 3 de 3
  • When choosing a replacement hard drive, make sure you are choosing one which is 7mm in height, and not the more traditional 9.5mm laptop drive, as it will not fit given the limited space inside of the laptop.
  • Using a PH0 sized screw driver, carefully remove the 4mm screw from the bottom cover.
  • Using the plastic opening tool carefully pry open the bottom cover
  • Slide the bottom cover towards you and remove it from the laptop base. Put the cover aside.
Insérez ici votre traduction
