Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Remplacement de l'écran LCD et du panneau frontal de l'iPhone SE
Informations sur le tutoriel
= Terminé = Incomplet
Replace the cracked or brokenFix a broken screen on your iPhone SE.SE by replacing just the bare front panel, a.k.a. LCD and digitizer assembly.
    Use this guideFor an easier repair, use our [product|IF327-011|fix kit|new_window=true] and follow [guide|61305|this shorter guide] to strip and replace your cracked or broken iPhone SEiPhone’s entire screen. It [ … ] For more advanced fixers, this guide will showhelp you replace ''only'' the iPhone SE LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you how to removetransfer several components from your original screen to the new one before installing it—including the home button, front-facing camera and sensor assembly,camera, earpiece speaker, and LCD shield plate—all of which will need to be transferred to your replacement front panel. If your replacement screen already has those parts, [https://www.ifixit.com/Guide/iPhone+SE+Display+Assembly+Replacement/61305|follow this much shorter guide instead].plate, and home button assembly. [ … ] In either case, it's important to transfer the ''original'' home button onto the new display in order for Touch ID (fingerprint scanning) to function. [ … ] This component is also compatible with the iPhone 5s. [ … ] '''You can also use this guide to replace the following parts:''' * [https://www.ifixit.com/Guide/iPhone+SE+Front+Panel+Replacement/61310#s52985|Front[ … ] * [guide|61310|Front Panel Assembly Cable Bracket]Bracket|stepid=52985] * [https://www.ifixit.com/Guide/iPhone+SE+Front+Panel+Replacement/61310#s58133|LCD[guide|61310|LCD Shield Plate]Plate|stepid=58133]
      Décrivez la pièce ou le composant spécifique de ce device sur lequel vous êtes en train de travailler. Par ex : batterie
      Créer un titre.
      Ce bref résumé n'apparaîtra que dans les résultats de recherche.
      Communiquez des informations de base avant que le lecteur ne se plonge dans le tutoriel.
      Étapes du tutoriel
