Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
After sufficiently heating a section of the edge, use the jimmy tool and slide it between the glass screen and the aluminum bezel of the phone. Proceed to gently slide the jimmy around the area that has been heated to remove the the screen from the adhesive. Having heat resistant gloves are very important as the device will get very hot and will burn your fingers if you come into contact directly with the phone.
Removing the screen
  • After sufficiently heating a section of the edge, use the jimmy tool and slide it between the glass screen and the aluminum bezel of the phone.
  • Proceed to gently slide the jimmy around the area that has been heated to remove the the screen from the adhesive.
  • Having heat resistant gloves are very important as the device will get very hot and will burn your fingers if you come into contact directly with the phone.
  • It might be helpful to use the picks to leave in between the glass and bezel so that the adhesive does not reattach.
  • Continue to follow Steps 1-2 through the perimeter of the phone to remove the adhesive.
Insérez ici votre traduction
