Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
After removing the adhesive and the screen is now loose from the phone, you'll notice that it is still attached to the back through a connector. On the back of the phone, unclip the connector to the screen located on the bottom right hand side of the phone using a plastic pry tool. Now that the pin is disconnected, you will have to gently slip the connector through the hole in the back of the phone to free the entire screen.
  • After removing the adhesive and the screen is now loose from the phone, you'll notice that it is still attached to the back through a connector.
  • On the back of the phone, unclip the connector to the screen located on the bottom right hand side of the phone using a plastic pry tool.
  • Now that the pin is disconnected, you will have to gently slip the connector through the hole in the back of the phone to free the entire screen.
  • Once the connector is slipped through the hole, the screen should be free from the phone for good.
Insérez ici votre traduction
