Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 1
Étape 1
Reheat the iOpener in the microwave for one minute. Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute. Place the heated iOpener on the back of the iPad just right of center (the side opposite the rear facing camera). Let it sit there for 90 seconds to soften the battery adhesive.
  • Reheat the iOpener in the microwave for one minute.
  • Remember to be careful not to overheat the iOpener during the repair procedure. Wait at least two minutes before reheating the iOpener, and never microwave it for more than one minute.
  • Place the heated iOpener on the back of the iPad just right of center (the side opposite the rear facing camera). Let it sit there for 90 seconds to soften the battery adhesive.
  • Move the iOpener to the center of the back of the iPad and let the iOpener sit for another 90 seconds.
  • If the iOpener cools significantly between sittings, reheat it for another minute.
  • Move the iOpener to the left edge (the side with the rear facing camera) of the back of the iPad and let the iOpener sit for another 90 seconds.
Réchauffez l'iOpener au micro-ondes pendant une minute.
Veuillez à ne pas surchauffer l'iOpener pendant la procédure de réparation. Attendez au moins deux minutes avant de réchauffer l'iOpener, et ne le laissez jamais au micro-ondes pendant plus d'une minute.
Placez l'iOpener chaud derrière l'iPad juste à droite du centre (le côté opposé à la caméra arrière). Laissez reposer pendant 90 secondes pour ramollir l'adhésif de la batterie.
Déplacez l'iOpener au centre de l'iPad et laissez l'iOpener agir pendant 90 secondes supplémentaires.
Si l'iOpener refroidit considérablement entre les poses, réchauffez-le pendant une autre minute.
Déplacez l'iOpener sur le bord gauche (du côté de la caméra arrière) de l'iPad et laissez l'iOpener agir pendant 90 secondes supplémentaires.
