Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 3
Étape 3
Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00. After the screws have been removed lift up on the motherboard to remove it from the case.
  • Once all cables have been disconnected from the motherboard, remove the seven remaining 3.0 mm screws with a Phillips head screwdriver size #00.
  • After the screws have been removed lift up on the motherboard to remove it from the case.
  • If you feel any pull when removing the motherboard, check to see if you did not disconnect a cable connected to the board.
Insérez ici votre traduction
