Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Before proceeding, note how the 3 ribbon cables are oriented (what direction the gold contacts face) and layered together (which cable is on top of which). The cables are too short to reach if they are threaded through in any other orientation. Slowly pull the upper display assembly away from the upper case. Make sure that the various ribbon cables are being fed through the slit in the upper case.
  • Before proceeding, note how the 3 ribbon cables are oriented (what direction the gold contacts face) and layered together (which cable is on top of which). The cables are too short to reach if they are threaded through in any other orientation.
  • Slowly pull the upper display assembly away from the upper case.
  • Make sure that the various ribbon cables are being fed through the slit in the upper case.
  • Separate the upper display assembly from the upper case.
Insérez ici votre traduction
