Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
So, what are resistors, and why do we care about them? Resistors are components used in circuitry to control the amount of current flow. The more resistance a resistor has (measured in Ohms, Ω), the less current it allows to flow.
  • So, what are resistors, and why do we care about them? Resistors are components used in circuitry to control the amount of current flow. The more resistance a resistor has (measured in Ohms, Ω), the less current it allows to flow.
  • The colored bands on a resistor are the key to determining the resistance of that particular resistor. A resistor color code chart will come in handy here.
  • If there are four bands on your resistor, the first band to locate is the red, gold, or silver band on one of the swollen ends; these are called tolerance bands. Since our resistors have gold bands, we know the actual resistance is within ±5% of the nominal value
  • The next step is to determine the nominal value of your resistor. Starting at the opposite side of the tolerance band and moving from left to right, there are three colored bands. The first two color bands correspond to a number (0-9), and the third band is the multiplier band, which corresponds to a specific power of 10.
  • Looking at the top resistor shown, we see yellow, violet, and red bands. Consulting a resistor color code chart shows us that those correspond to 4, 7, and 100, respectively, giving us a nominal resistance of 4,700 Ω.
  • Can you determine the resistance of the bottom resistor?
Alors, c'est quoi les résistances et pourquoi sont-elles importantes ? Les résistances sont des composants de circuits électroniques utilisés pour contrôler l'intensité électrique qui traverse un circuit. Plus une résistance a une résistance élevée (mesurée en ohms, Ω), plus elle freine le passage du courant.
La clé pour déterminer la valeur d'une résistance, ce sont les anneaux de couleur qu'on peut voir dessus. Un tableau des couleurs des résistances sera utile pour ça.
S'il y a quatre anneaux sur votre résistance, le premier à repérer est le rouge, doré ou argenté, situé sur l'une des extrémités gonflées. Ce sont les anneaux de tolérance. Nos résistances ont des anneaux de couleur "or", donc on sait que la valeur réelle peut être située à ± 5 % de la valeur nominale.
L'étape suivante est de déterminer la valeur nominale de la résistance. En partant du côté opposé à l'anneau de tolérance, on lit la valeur de gauche à droite : les deux premières couleurs correspondent chacune à un chiffre entre 0 et 9, et le dernier anneau donne un multiplicateur qui est une certaine puissance de 10.
Si on revient à la résistance du dessus sur notre photo, on voit des anneaux jaune, violet et rouge. Le tableau nous indique que cela correspond à 4, 7 et 100 respectivement, ce qui nous donne une résistance nominale de 4700 Ω.
Pouvez-vous déterminer la valeur de la résistance du dessous ?
