Aller au contenu principal
Anglais
Français
Traduction de l’étape 24
Étape 24
Obviously, your solder creation needs to have a super sweet sound system ... or this speaker. Close enough, right? Note the + on the face of the speaker. When installing the speaker, be sure to line this + up with the + on the circuit board. Insert the leads through the holes located in the circle labeled LS, making sure to match up the positive terminals.
  • Obviously, your solder creation needs to have a super sweet sound system ... or this speaker. Close enough, right?
  • Note the + on the face of the speaker. When installing the speaker, be sure to line this + up with the + on the circuit board.
  • Insert the leads through the holes located in the circle labeled LS, making sure to match up the positive terminals.
Evidemment, votre création soudée nécessite un système de son tip top... ou ce haut-parleur. On se rapproche, non ?
Remarquez le + sur le dessus du haut-parleur. Il devra correspondre au + inscrit sur le circuit imprimé.
Insérez les pattes à travers les trous situés dans le cercle LS, en faisant attention à la polarité (+ avec +).
