Aller au contenu principal
Anglais
Français
Traduction de l’étape 29
Étape 29
Repeat the surface mount soldering procedure for the negative battery terminal lead. Be sure to install the lead so that the excess wire hangs off the opposite side rather than the positive terminal lead.
  • Repeat the surface mount soldering procedure for the negative battery terminal lead. Be sure to install the lead so that the excess wire hangs off the opposite side rather than the positive terminal lead.
  • Now that you have installed whiskers on your circuit board, it's time to pet it and buy it a scratching post. Wait, that's not right . . .
Répétez l'opération de soudure TMS pour la patte de la borne négative du compartiment à piles. Faites en sorte que la patte pende de la carte à l'opposé de la borne positive.
Maintenant que vous avez installé les moustaches de votre circuit, il est temps de l'amadouer et de lui acheter un griffoir. Attendez... Non, c'est pas ça...
