Aller au contenu principal
Anglais
Français
Traduction de l’étape 36
Étape 36
Use a pair of wire cutters to remove about an inch of the positive terminal surface mount lead. Bend the lead around and through the positive ring terminal on the battery compartment. Use your now perfected through-hole soldering skills to solder the lead to the battery terminal.
  • Use a pair of wire cutters to remove about an inch of the positive terminal surface mount lead.
  • Bend the lead around and through the positive ring terminal on the battery compartment.
  • Use your now perfected through-hole soldering skills to solder the lead to the battery terminal.
  • Cut off any excess lead.
Utilisez une pince coupe-fil pour retirer environ un centimètre de la patte au niveau de la borne positive.
Pliez la patte pour la faire passer dans l'anneau positif du compartiment à piles.
Utilisez votre technique (maintenant parfaite) de brasage traversant pour souder la patte à la borne.
Couper la longueur inutile.
